allen18
3 years agocan two emif ipcores share bank?
Hi : I will use two 16bit ddr4 controller, the readme.txt file show a example I/O assignments, if this one controller will occupy two banks, total 4 banks. Two controllers working at same fre...
- 3 years ago
This is how resource sharing for EMIFs is supposed to be set up and work, so you shouldn't have an issue.
allen18
3 years agoHi, The device is stratix10 1SX110HN2F43I2VG, I plan to use the hard DDR controllers in bank 3L and 3J. For the first controller, I will place the address and command signals in bank 3L, and place 8 DQ signals in bank 3L. The remaining 8 DQ signals placed in bank 3K. For the second controller, I will place the address and command signals in bank 3J, and place 8 DQ signals in bank 3J. The remaining 8 DQ signals will also be placed in bank 3K. Both controllers will share the same reference clock input.Full compilation was successful but I am worried about the practical feasibility of it.
