12 years ago
Can the connect() for a TCP client be configured as "blocking" ?
I'm developing a TCP client using NicheStack.
Currently, if no server is listening for the connection the connect() returns -1.
So, I have to put the connect() in a loop with a 500 millisecond delay between connection attempts.
    It's done when you create the socket and I believe it is blocking by default...in most network stacks. Double-check your socket settings.
    Yes, the socket is blocking by default.
    In order to set non-blocking mode you must call:
    setsockopt(your_socket, SOL_SOCKET, SO_NONBLOCK, &max_socket, sizeof(int));
    IIRC you could also set the default behaviour in Nichestack configuration file ipport.h
    Thanks for confirming that the connect() should block by default. For some unknown reason, in my case, it does not block.
    I have tried to use setsockopt() to guarantee that the socket is setup as "blocking" but the connect() stills returns -1
    if a server is not currently listening.
    By the way, my recv() call does block as expected. I'm going to continue to investigate
    why the connect() is not behaving as expected. I'm also going to check out the file "ipport.h".
    After doing further investigation (using the debugger), the error causing the connect() to return -1 is ECONNREFUSED.
    Of course, since there's no server listening for this client that would make sense but since the connect() should
    be blocked until the server is listening, why is the error ECONNREFUSED ?
