16 years agocan quartus break the compilation?
Hi Experts, I've ran into very weird problems. I have a design which is simulated (including time simulation), works in testbench without any problems. then i burn it in and under 'certain' condit...
16 years agoi had these mysterical behavioral when i started with quartus that adding signaltap lead to a different behavioral of the design.
daixiwen is correct, it was some kind of timing problem. to specify only the input clock and maybe indirectly other clocks via a pll does not constrain the design. do you have a fully synchronous design ? or do you have some logic that depends upon more than only one clock ? i had designs where a verilog code always @ ( posedge clk or negedge nreset) lead to nreset as a clock signal, but only for a few registers within the same modul.
