16 years agocan quartus break the compilation?
Hi Experts, I've ran into very weird problems. I have a design which is simulated (including time simulation), works in testbench without any problems. then i burn it in and under 'certain' condit...
16 years agoUsually this indicates a timing problem. Did you properly constrain all your input/outputs, and do you have any critical warning from Timequest when you compile your design?
