15 years agocan open-drain output bear voltage of 5V?
Hi there, I want to use 5V output but cyclone ii device does not support the 5V IO standard. I know that cyclone ii device can configed as open-drain outputs, can I pull the OD ports up to 5V? Is...
15 years agosorry for that.
I have read spec sheet in wrong way.
