15 years agocan open-drain output bear voltage of 5V?
Hi there, I want to use 5V output but cyclone ii device does not support the 5V IO standard. I know that cyclone ii device can configed as open-drain outputs, can I pull the OD ports up to 5V? Is...
15 years agoMAX II also isn't 5V tolerant. MAX 3000 in contrast is.
