15 years agocan open-drain output bear voltage of 5V?
Hi there, I want to use 5V output but cyclone ii device does not support the 5V IO standard. I know that cyclone ii device can configed as open-drain outputs, can I pull the OD ports up to 5V? Is...
15 years ago --- Quote Start --- Is there any risk to the FPGA device? --- Quote End --- You shouldn't do that, it's clearly beyond maximum ratings. You should at least implement PCI clamp diodes for the respective outputs.
