17 years agoCan not write or read in SDR SDRAM
Hi, I am using FPGA Stratix II EP2S60F1020C4. This FPGA board has 2 SDRAM ( Micron MT48LC4M32B2 ) configured as 64-bit bus. These two SDRAM have their control signals connected on the same pins of...
17 years agoThank you very much for your kind answer.
I have attached here my project for SDRAM control so that you can check it conveniently. I hope you will help me to point out what is wrong with my project. It is really important for me to get through this problem because it is one part of my master thesis. By the way, thank you very much for your helpful advice about Signal Tap II. I will try to use it. Looking forward to your reply.:) https://www.alteraforum.com/forum/attachment.php?attachmentid=1137
