14 years agoCan not reprogram EPCS device
Dear Gurus,
While programming jic file from JTAG, power is turned off and I can not reprogram it again. Is there a way to hard reset the device and make it working or do I need to replace it. regards1 Reply
jic file usually reprograms ecps device from scratch, so a power off during the process should not be an issue, unless it generated some hardware damage because of other hazardous conditions occurring (i.e. ESD, power surges, devices connected to fpga were still powered on ...)
From your message I guess the jic itself is definitely not the problem. I mean you can use the same file to successfully program ecps on another board, can't you?
