Can not program Agilex-5 device
- 7 months ago
Problem solved I had to use special "CS" OPN. Then it all worked.
Hi AnttiLukats,
The errors you see match a known case where the timing models for this device are not yet final. Hence SOF generation also is not enabled yet..
Please review:
KDB: Why can’t the Agilex 5/7 programming file be generated?
https://community.altera.com/kb/knowledge-base/why-cant-the-agilex%E2%84%A2-5-or-agilex%E2%84%A2-7-fpga-programming-file-be-generated-in-the-qu/345059
Community thread showing the workaround via quartus.ini and correct OPN selection:
https://community.altera.com/discussions/quartus-prime/quartus-25-1-0-not-producing-sof-file/311247
Next steps:
- In Quartus, select the exact Ordering Part Number printed on your device and recompile.
- Update to the latest Quartus Prime Pro with the Agilex 5 device pack.
- If Warning 18636 still blocks .sof, I will request the temporary INI from software team, then recompile and program.
Fakhrul
- FakhrulA_altera7 months ago
I’m glad that your question has been addressed, I now transition this thread to community support. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Altera experts. Otherwise, the community users will continue to help you on this thread. Thank you.
