Can not program Agilex-5 device
- 7 months ago
Problem solved I had to use special "CS" OPN. Then it all worked.
we tried flashing with wrong SOF, when we select proper device then SOF is not generated at all, with following:
Critical Warning(18636): Compilation Report contains advance information. Specifications for device A5EE013BB23BE6S are subject to change. Contact Altera for information on availability. No programming file will be generated.
Dear Altera what should we do?
Hi AnttiLukats,
The errors you see match a known case where the timing models for this device are not yet final. Hence SOF generation also is not enabled yet..
Please review:
KDB: Why can’t the Agilex 5/7 programming file be generated?
https://community.altera.com/kb/knowledge-base/why-cant-the-agilex%E2%84%A2-5-or-agilex%E2%84%A2-7-fpga-programming-file-be-generated-in-the-qu/345059
Community thread showing the workaround via quartus.ini and correct OPN selection:
https://community.altera.com/discussions/quartus-prime/quartus-25-1-0-not-producing-sof-file/311247
Next steps:
- In Quartus, select the exact Ordering Part Number printed on your device and recompile.
- Update to the latest Quartus Prime Pro with the Agilex 5 device pack.
- If Warning 18636 still blocks .sof, I will request the temporary INI from software team, then recompile and program.
Fakhrul
- AnttiLukats7 months ago
- FakhrulA_altera7 months ago
I’m glad that your question has been addressed, I now transition this thread to community support. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Altera experts. Otherwise, the community users will continue to help you on this thread. Thank you.
