Can not config cyclone V 5CGXFC9D6F27I7 through EPCQ128
This is a board used for many versions, and this question is the first time I met, I can download the .jic file through Usb-blaster ii to the FPGA, and quarus show these meassage which means the configuration is sucessful.
Info (209060): Started Programmer operation at Mon Mar 07 10:44:32 2022
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x02B040DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209018): Device 1 silicon ID is 0x18
Info (209044): Erasing ASP configuration device(s)
Info (209019): Blank-checking device(s)
Info (209023): Programming device(s)
Info (209021): Performing CRC verification on device(s)
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Mon Mar 07 10:58:33 2022
when I power down the board, and power up the board again, FPGA can not load the code from EPCQ128 to my FPGA, I measured the conf_done PIN, it is low, but when i measure it before I power down, it is high, which means the PIN is ok, and i have put a 10KΩ pull up with it, at the same time, nStatus PIN keep toggling with 376us high and 256us low.
If I do not use the code in EPCQ128, and only use .sof through JTAG downloaded, I can run my code correctly, so i think the FPGA is good, but if EPCQ was broken, why the quartus can perform CRC verification correctly?
Thanks and best regards
1 Reply
- YuanLi_S_Intel
You mentioned that the flow was worked in the past on the other quartus version. May i know what are the changes u made recently?
Having configuration failure could be due to several issue, you may check our troubleshooting guide for that:
