WKUAN
4 years agoCan not config cyclone V 5CGXFC9D6F27I7 through EPCQ128
This is a board used for many versions, and this question is the first time I met, I can download the .jic file through Usb-blaster ii to the FPGA, and quarus show these meassage which means th...
YuanLi_S_Intel
4 years agoYou mentioned that the flow was worked in the past on the other quartus version. May i know what are the changes u made recently?
Having configuration failure could be due to several issue, you may check our troubleshooting guide for that:
