James_B
Contributor
7 years agoCan Max10 devices be filled 100% for logic utilization?
I have a design that has gone to production with a customer. The 10M08 device that I am using is 96% full, and the compilation time is quite reasonable for this percentage of logic use. My question i...
KhaiChein_Y_Intel
7 years agoHi James B,
When you have a larger design, the complexity is higher. A small or simpler design can achieve higher logic utilization compared to the larger design. If you use similar % of the logic utilization in the larger and complex design, you will easily see some fitter issue or timing issue.
