Anonymous
1 month agoNot applicable
Can MAX10-DC compact device supports RSU feature?
Hi, I want to know if MAX10-DC compact device can supports RSU feature. If not support, can I implement remote update to update just a single image on CFM0?
FvM
30 days agoHi,
as stated Compact MAX10 doesn't support Dual Config IP and respective features, e.g. reconfig command. Rewriting CFM in user mode is nevertheless possible. You'll just miss the fallback to factory image in case of programming error or unexpected power fail. As long as no reconfig is issued, you can however verify and possibly correct flash content.
I'm not sure if a built-in way to cause reconfiguration without external NCONFIG asserting or power cycle. In case of doubt, NCONFIG can be wired to a GPIO pin.
Regards Frank
