REics
3 years agoCan I use the same programming file on different packages?
I want to use the same programming file in 10CL016YU256 and 10CL016YU484. Can this be done, provided that I use only pins/pads bonded in both device packages?
FakhrulA_altera
3 years agoHi REics,
Technically you cannot use the same programming file across different packages as the pin's locations are different on each package.
You may perform the migration across the devices within the same package type as you can see in the table below:
Perhaps you may need to update the pin assignment in your design on a different package type.
Fakhrul
