16 years agoCan I use flash memory in Cyclone and StratixII?
Are there anyone able to tell me whether I can use flash memory in a cyclone or stratix? Thanks! Peter Chang4 Replies
Hi Artem,
Thanks for your commend. In FPGA, it can have an UFM to generate flash memory in chip. MAXII is able to support the function. Peter - Altera_Forum
--- Quote Start --- Hi Artem, What I want to do is to design a flash memory in a chip of either CycloneIII or StratixII. It may use a technology like UFM in MAXII. For your reference. Thank you! --- Quote End --- I think you need ASIC design. Not just "hardcopy". Maybe a battery powered memory will be enough? - Altera_Forum
Hi Artem,
What I want to do is to design a flash memory in a chip of either CycloneIII or StratixII. It may use a technology like UFM in MAXII. For your reference. Thank you! Peter Chang - Altera_Forum
--- Quote Start --- Hi, Are there anyone able to tell me whether I can use flash memory in a cyclone or stratix? Thanks! --- Quote End --- NAND? NOR? SPI? You can make SPI on you FPGA and connect any SPI flash memory. http://atmel.com/products/serial/default.asp
