15 years agoCan I use a normal pin as DDR2 controller's DQ?
I make a mistake when I do the schmatics work, so I must use a normal pin as DDR2 controller's DQ. When I complie the project, I face the error: altmemphy pin placement unsuccessful.The assigned l...
15 years agoStratix family? If you look through the handbook, the hardware has specially structures on the DQS ports that are used by the PHY. If it used "generic" FPGA structures, it would never meet timing.
