15 years agoCan I use a normal pin as DDR2 controller's DQ?
I make a mistake when I do the schmatics work, so I must use a normal pin as DDR2 controller's DQ. When I complie the project, I face the error: altmemphy pin placement unsuccessful.The assigned l...
15 years agoThe DDR2 controller is required to use DQ/DQS groups according to the assignments in device pinout files. Unfortunately you have to change the layout.
