8 years ago
Can I use 6+2 PCIe ATX power connector to power supply Arria 10 Dev Kit?
Hi all,
I read from the Arria 10 Dev Kit User Guide (Page 51 in https://www.altera.com/content/dam/altera-www/global/en_us/support/boards-kits/arria10/fpga/a10-fpga-dk-ug.pdf) that, when plugging the board into a PCIe slot, we should not power supply the board via the 12-V DC jack (J13); instead, it seems that we should be using a 12-V "PCIe 2x4 ATX power connector" for the power supply (J4).
My question is, my PSU only provides two "PCIe 6+2 ATX power connector" for powering PCIe devices; the PSU's 2x4 connector is for motherboard/CPU. I also googled and found that a 2x4 ATX connector is a rarely seen format for PCIe ATX connector. So, is plugging the 6+2 PCIe ATX connector to the Dev Kit OK? The pin patterns (shapes) of the 6+2 connector match perfectly with those of the ATX port on the Dev Kit (which means that I can plug the connector to the port easily without forcing it), and on the 6+2 connector it prints "PCI-E". Based on these observations, my guess was that the 6+2 connector should work; but I also want to make sure doing this won't destroy my board.
Does anyone has any experience on this? Any hint or suggestion is appreciated!
    Hi TCWORLD,
    Thank you for helping me make sure. I confirm that the Arria 10 Dev Kit can be powered by the PCIe 6+2 ATX connector without a problem. Also, the tip of checking the schematic is useful! Thank you so much!
    --- Quote Start ---
    By PCIe 2x4 ATX connector, they are in fact meaning a PCIe 6+2 ATX connector like you would use for a graphics card.
    They do not mean an ATX EPS12V connector (8pin CPU connector). Using a CPU connector would likely destroy the board.
    You can see this from page 31 of the schematic (https://www.altera.com/content/dam/altera-www/global/en_us/support/boards-kits/arria10/fpga/a10gx_pcie_e3p1.pdf) - pins 1 to 3 are +12V, and the rest are connected to GND which corresponds to the pin-out of the PCIe 6+2 connector. The pins named "sense" on that connector in the schematic is a further confirmation as only the PCIe 6+2 has those.
    --- Quote End ---
    Thanks for the suggestion @TCWORLD! The board can be successfully powered by the 6+2 connector :)
