RPDM
7 years agoCan I use 50 Ohm calibrated bidirectional pins on an Arria 10 - seems not?
So I've replicated this on two different Arria 10 devices (10AX027 & 10AS066) and if I create a bidirectional pin I cannot get it to output something if set to a 50 Ohm calibrated output. So: set to...
- 7 years ago
Hi RPDM,
It is hardware restriction that bidirectional cannot have OCT for GPIO. However, when the I/O pin is used with external memory interface IP, bidirectional with OCT is allowed.
YL
RPDM
7 years agoHi,
Yes, that's correct.
When set to uncalibrated, the bidirectional pin works correctly.
When set to calibrated, the bidirectional pin does not output anything.
Richard
