RPDM's avatar
RPDM
7 years ago
Can I use 50 Ohm calibrated bidirectional pins on an Arria 10 - seems not?
So I've replicated this on two different Arria 10 devices (10AX027 & 10AS066) and if I create a bidirectional pin I cannot get it to output something if set to a 50 Ohm calibrated output.
So: set to 1.8v 50 Ohm uncalibrated, it outputs the expected signal (when the output enable I send to the pin is high, of course).
But: just change uncalibrated to calibrated (with a reference 100 Ohm RZQ pin), and there's no output - just a signal at GND.
Changing the bidirectional ability to just being an output pin, still 50 Ohm calibrated, works fine.
The Handbook appears to show what I'm doing is valid - but it doesn't work...
  • YuanLi_S_Intel's avatar
    YuanLi_S_Intel
    7 years ago
    Hi RPDM,
    It is hardware restriction that bidirectional cannot have OCT for GPIO. However, when the I/O pin is used with external memory interface IP, bidirectional with OCT is allowed.
    YL
  • RPDM's avatar
    RPDM
    Hi Yuan,
    I have checked 4 different pins on a 10AX027H4F35E3SG device, plus 1 pin on the 10AS066 that's on the SoC dev board. All behave in the same way.
    Some tests I've done:
    • Pin = inout, GPIO IP = Bidirectional, Calibration = On, Result = No output
    • Pin = inout, GPIO IP = Bidirectional, Calibration = Off, Result = OK
    • Pin = inout, GPIO IP = Output with OE (variable), Calibration = On, Result = No output
    • Pin = inout, GPIO IP = Output with OE (fixed to '1'), Calibration = On, Result = No output
    • Pin = inout, Simple Verilog code with OE (Variable), Calibration = On, Result = No output
    • Pin = inout, Simple Verilog code with OE (Variable), Calibration = Off, Result = OK
    • Pin = output, GPIO IP = Output with OE (variable), Calibration = On, Result = OK
    Resource Property Viewer shows the correct connections in all cases. It also shows Open Drain = Off.
    The "Simple Verilog code with OE" was just this (showing just the appropriate lines of code):
    inout m1_c1_dq10,
    assign m1_c1_dq10 = counter[2] ? counter[0] : 1'bZ;
    With the above, calibrated outputs fail, non-calibrated ones work. RPV shows the correct connections (with Open Drain=Off).
    Richard
      YuanLi_S_Intel
      ​Hi Richard,
      May I know which quartus version you are using? I have checked with internal team, OCT cannot be enabled for bidirectional pin.
      YL
        YuanLi_S_Intel
        Hi RPDM,
        YL
    YuanLi_S_Intel
    Hi Richard,
    This is abnormal, by right it should work. Can you check on the other pin?
    Thank You.
    Yuan Li
  • RPDM's avatar
    RPDM
    Yes, that's correct.
    When set to uncalibrated, the bidirectional pin works correctly.
    When set to calibrated, the bidirectional pin does not output anything.
    Richard
    YuanLi_S_Intel
    Hi RPDM,
    Apologize that I don’t understand the enquiry. Are you saying that the bidirectional pin in Arria 10, there is no problem in using 50 Ohm uncalibrated On-chip termination (OCT) but there is problem in using 50 Ohm calibrated OCT?
    YL
