RPDM
7 years agoCan I use 50 Ohm calibrated bidirectional pins on an Arria 10 - seems not?
So I've replicated this on two different Arria 10 devices (10AX027 & 10AS066) and if I create a bidirectional pin I cannot get it to output something if set to a 50 Ohm calibrated output. So: set to...
- 7 years ago
Hi RPDM,
It is hardware restriction that bidirectional cannot have OCT for GPIO. However, when the I/O pin is used with external memory interface IP, bidirectional with OCT is allowed.
YL
YuanLi_S_Intel
7 years agoHi Richard,
May I know which quartus version you are using? I have checked with internal team, OCT cannot be enabled for bidirectional pin.
YL
RPDM
7 years agoHi Yuan,
My last test was using 18.1. I've not tried since.
This is obviously an issue for us. Will it be fixed in a newer version of Quartus, or is it a hardware issue?
I am assuming that it does not affect Intel's External Memory Interface IP, since that obviously needs calibrated bi-directional pins?
Richard
