8 years agoCan I safely ignore warning that output pin cannot be tristated?
Dear all, I have the following code for driving the output and input of my design:
Fout_DATA <= DATA;
Fout_BE <= BE;
Fout_RXF <= RXF;
Fout_TXE <= TXE;
WR <= Fin_WR;
DATA(31 downto 16) <= i...
8 years agoDear Tricky and eapenabrm,
thank you for your answers. Above mentioned code is not in the top module but in an underlying module IO_control. The module IO_control is getting the signals directly from the top module. The top module entity is this:
entity mainboard_top is
port ( RESET_F : IN STD_LOGIC;
RESET_H : IN STD_LOGIC;
CLOCK_50_B5B : IN STD_LOGIC;
CLOCK_50_B6A : IN STD_LOGIC;
GPIO : INOUT STD_LOGIC_VECTOR(36 downto 0);
SW : IN STD_LOGIC_VECTOR(9 downto 0);
LEDG : OUT STD_LOGIC_VECTOR(7 downto 0);
LEDR : OUT STD_LOGIC_VECTOR(9 downto 0);
KEY : IN STD_LOGIC_VECTOR(4 downto 0);
-- Master interface
CLK : IN STD_LOGIC;
DATA : INOUT STD_LOGIC_VECTOR(31 downto 0);
BE : INOUT STD_LOGIC_VECTOR(3 downto 0);
RXF_N : IN STD_LOGIC;
TXE_N : IN STD_LOGIC;
WR_N : OUT STD_LOGIC;
SIWU_N : OUT STD_LOGIC;
RD_N : OUT STD_LOGIC;
OE_N : OUT STD_LOGIC);
end entity mainboard_top;
The IO_control module directly connects to the DATA INOUT (the red one) of the top module (and also for the byte_enabled port, the green one): I do not have additional signals between IO_control outputs and in/outputs of top module but I rather attached the pins directly. Is this critical?
architecture behaviour of mainboard_top is
begin
io_control_inst1 : io_control
port map ( CLK => CLK,
RESET => RESET_F,
DATA => DATA,
BE => BE,
and the IO_control code is:
LIBRARY IEEE;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity io_control is
port ( CLK : IN STD_LOGIC;
RESET : IN STD_LOGIC;
TXE : INOUT STD_LOGIC;
RXF : INOUT STD_LOGIC;
WR : OUT STD_LOGIC;
Fin_DATA_ram : IN STD_LOGIC_VECTOR(31 downto 0);
Fin_DATA_ep : IN STD_LOGIC_VECTOR(3 downto 0);
Fin_BE : IN STD_LOGIC_VECTOR(3 downto 0);
DATA_out_en : in STD_LOGIC;
BE_out_en : in STD_LOGIC;
send_command : in STD_LOGIC;
Fin_WR : in STD_LOGIC;
Fout_DATA : out STD_LOGIC_VECTOR(31 downto 0);
Fout_BE : out STD_LOGIC_VECTOR(3 downto 0);
Fout_RXF : out STD_LOGIC;
Fout_TXE : out STD_LOGIC);
end entity io_control;
architecture behaviour of io_control is
SIGNAL int_DATA : STD_LOGIC_VECTOR(31 downto 0);
SIGNAL command : STD_LOGIC_VECTOR(31 downto 0);
begin
Fout_DATA <= DATA;
Fout_BE <= BE;
Fout_RXF <= RXF;
Fout_TXE <= TXE;
WR <= Fin_WR;
DATA(31 downto 16) <= int_DATA(31 downto 16) when (BE_out_en = '0') else
"ZZZZZZZZZZZZZZZZ" when (BE_out_en = '1') else
(others => 'X');
DATA(15 downto 8) <= int_DATA(15 downto 8) when (DATA_out_en = '0') else
"ZZZZZZZZ" when (DATA_out_en = '1') else
(others => 'X');
DATA(7 downto 0) <= int_DATA(7 downto 0) when (BE_out_en = '0') else
"ZZZZZZZZ" when (BE_out_en = '1') else
(others => 'X');
BE <= Fin_BE when (BE_out_en = '0') else
"ZZZZ" when (BE_out_en = '1') else
(others => 'X');
command <= ("000000000000000000000000" & "0000" & Fin_DATA_ep);
data_mux : process(CLK, RESET)
begin
if (RESET = '0') then
int_DATA <= (others => '1');
elsif (rising_edge(CLK)) then
if (send_command = '1') then
int_DATA <= command;
elsif (send_command = '0') then
int_DATA <= Fin_DATA_ram;
end if;
end if;
end process data_mux;
end architecture behaviour; You see that I changed the (others => '0') to (others => 'X'). Fout_DATA is an output of the IO_Control, how should Fout_DATA drive the DATA bus of IO_control? I see no reason since it is clearly an output?! I do not see another possibility to read the signals from the DATA bus. Or should I rather put all this in a process and make a complex IF-query? Should I rather implement this in the top module? I do not understand why this is critical. VHDL Modules are for user friendliness and in my understanding do not determine where fitter is placing the IOCELLS, BUFS, MUXes etc etc.? Again thank you for your help!
