Can I make stand-alone NiosII system?
Hi,all.
I am going to build the stand-alone NiosII system. Already, I could build PC-connecting NiosII system but I don't know how to build the stand-alone (so PC-NOT-connecting) NiosII system. What I programmed system is volatile. So I think that it is a correct answer to program the system data into a flashmemorydevice. But the system has NO flashmemorydevice.(in Qsys system,Flash Memory Interface) Can I make stand-alone NiosII system? Though I think I only add Flash Memory Interface, I don't know how to connect it to the other component. Please tell me. Thanks all.15 Replies
There should be a button when you perform the flash programming to tell the tools to ignore the system ID check. The System ID component is a simple little component meant to save you headaches when you accidentally have a mismatch between your .sof and intended hardware target (it's an oops detector). I highly recommend connecting it to your Nios II data master while you are the development stage of your project, once you get closer to finalizing you can remove it. It doesn't hurt to leave it in your system since it's a very small core (probably adds no more than 96 LEs to your hardware).
There is some online training (free) on the Altera website on configuring FPGAs that covers the various methods and options for loading configuration and state info, including host based and serial configuration devices.
Good luck - Altera_Forum
--- Quote Start --- This is what I mean about baking the software right into the .sof file: 1) Generate your system in SOPC Builder/Qsys, make sure a large on-chip memory is present and it is configured to be pre-initialized. 2) Create and compile your software, ensure that a .hex file is created for the on-chip memory 3) Compile your hardware design in Quartus --- Quote End --- How do I do step# 2? I can't find a setting in the Nios tool to do this. Once I have this, do I then use this .hex file in QSYS on-chip memory configuration in place of the default "onchip_mem.hex"? - Altera_Forum
I figured out how to do step# 2. Actually, there are directions for this in the "Nios II Software Developer's Handbook" (May 2011), pg 2-31, "Creating Memory Initialization Files". My Nios app. will now run following power-up/reset, booting from flash.
I am sorry that I did not reply sooner to you.
Since other work was busy, I was not able to spare time for programming. Since QuartusII stops because of another error now, I try your advice, after solving it.
