Can I make stand-alone NiosII system?
Hi,all.
I am going to build the stand-alone NiosII system. Already, I could build PC-connecting NiosII system but I don't know how to build the stand-alone (so PC-NOT-connecting) NiosII system. What I programmed system is volatile. So I think that it is a correct answer to program the system data into a flashmemorydevice. But the system has NO flashmemorydevice.(in Qsys system,Flash Memory Interface) Can I make stand-alone NiosII system? Though I think I only add Flash Memory Interface, I don't know how to connect it to the other component. Please tell me. Thanks all.15 Replies
I am sorry that I did not reply sooner to you.
Since other work was busy, I was not able to spare time for programming. Since QuartusII stops because of another error now, I try your advice, after solving it. - Altera_Forum
I figured out how to do step# 2. Actually, there are directions for this in the "Nios II Software Developer's Handbook" (May 2011), pg 2-31, "Creating Memory Initialization Files". My Nios app. will now run following power-up/reset, booting from flash.
--- Quote Start --- This is what I mean about baking the software right into the .sof file: 1) Generate your system in SOPC Builder/Qsys, make sure a large on-chip memory is present and it is configured to be pre-initialized. 2) Create and compile your software, ensure that a .hex file is created for the on-chip memory 3) Compile your hardware design in Quartus --- Quote End --- How do I do step# 2? I can't find a setting in the Nios tool to do this. Once I have this, do I then use this .hex file in QSYS on-chip memory configuration in place of the default "onchip_mem.hex"? - Altera_Forum
There is some online training (free) on the Altera website on configuring FPGAs that covers the various methods and options for loading configuration and state info, including host based and serial configuration devices.
Good luck - Altera_Forum
There should be a button when you perform the flash programming to tell the tools to ignore the system ID check. The System ID component is a simple little component meant to save you headaches when you accidentally have a mismatch between your .sof and intended hardware target (it's an oops detector). I highly recommend connecting it to your Nios II data master while you are the development stage of your project, once you get closer to finalizing you can remove it. It doesn't hurt to leave it in your system since it's a very small core (probably adds no more than 96 LEs to your hardware).
good morning
this happens because the system id peripheral at your sopc builder...... open your sopc builder and look at this peripheral ...... has a system id and time stamp...... i dont like to use this peripheral ......you can only remove this and re-generate sopc and recompile your project and works........ cheers Franz Wagner - Altera_Forum
Thanks, BadOmen.
--- Quote Start --- For flash programming that would be the best document to read. It might point you at other documents as well. --- Quote End --- I finished reading thah briefly. --- Quote Start --- This is what I mean about baking the software right into the .sof file: 1) Generate your system in SOPC Builder/Qsys, make sure a large on-chip memory is present and it is configured to be pre-initialized. 2) Create and compile your software, ensure that a .hex file is created for the on-chip memory 3) Compile your hardware design in Quartus The hex file created in# 2 becomes part of the hardware image in step# 3. So when the .sof generated in step# 3 you now have a hardware image that contains both the hardware design and software contents pre-initialized in the on-chip RAM. This is only feasible if your software is fairly small since on-chip memory is a limited resource in FPGAs. --- Quote End --- Although I tried many things, the following errors come out and Flash-Programmer is not completed. *Connected system ID hash not found on target at expeted not found on target at expected base address. *Connected system timestamp not found on target at expected base address. But my Nios II project run as "Run as" mode. I don't know how to solve that errors. Do you know any idea? - Altera_Forum
This is what I mean about baking the software right into the .sof file: 1) Generate your system in SOPC Builder/Qsys, make sure a large on-chip memory is present and it is configured to be pre-initialized. 2) Create and compile your software, ensure that a .hex file is created for the on-chip memory 3) Compile your hardware design in Quartus The hex file created in# 2 becomes part of the hardware image in step# 3. So when the .sof generated in step# 3 you now have a hardware image that contains both the hardware design and software contents pre-initialized in the on-chip RAM. This is only feasible if your software is fairly small since on-chip memory is a limited resource in FPGAs. - Altera_Forum
I am sorry that I did not reply to you sooner.
--- Quote Start --- If your software is small enough you can also pre-initialize on-chip memory to hold the software contents so that you don't need to copy it out of flash. You would still need to program the FPGA but the Nios II software contents would be part of it so that Nios II starts running as soon as the FPGA is configured. --- Quote End --- Well, I can't image that "Nios II software contents would be part of it". Hmmm.. I don't know how to do it. Although I am reading Nios II Flash Programmer User Guide now, do you know the document which is consulted more? - Altera_Forum
