14 years agoCan I make stand-alone NiosII system?
Hi,all. I am going to build the stand-alone NiosII system. Already, I could build PC-connecting NiosII system but I don't know how to build the stand-alone (so PC-NOT-connecting) NiosII system....
14 years agoFor flash programming that would be the best document to read. It might point you at other documents as well.
This is what I mean about baking the software right into the .sof file: 1) Generate your system in SOPC Builder/Qsys, make sure a large on-chip memory is present and it is configured to be pre-initialized. 2) Create and compile your software, ensure that a .hex file is created for the on-chip memory 3) Compile your hardware design in Quartus The hex file created in# 2 becomes part of the hardware image in step# 3. So when the .sof generated in step# 3 you now have a hardware image that contains both the hardware design and software contents pre-initialized in the on-chip RAM. This is only feasible if your software is fairly small since on-chip memory is a limited resource in FPGAs.
