SShaw4
5 years agoCan I create an output bin file?
Quartus version 17.0
Device 10M04SCU169, 32M flash CFI is attached for field upgrade.
I'm modifying software and regularly click "file ... ConvertProgrammingFile", then go to "programmer" and l...
ak6dn
5 years agoIn the past I found the easiest way to do this was to use the USB Blaster and program all the required files into a real device on the real board.
Then we would either attach a USB PROM device reader/programmer to the device, and dump it's contents to a programming file.
Or in some instances the programming house wanted a physical device programmed with what we would want, so we would desolder and send one.
Not what you wanted to hear I suspect, but we needed to get it done and (then) Altera had no tools to build a flash device image from files.
AFAIK they still have no tool like that.
