Can I create an output bin file?
May I know what do you mean by .bin file that holds everything?
Or are you looking for programming file such as RPD, JIC, etc..?
Aiman
Thanks Aiman. I downloaded a screen pic showing the fpga, memory, and files.
My understanding is that the top pof file holds logic, and the bottom pof file ( SSmcfirmware.pof ) holds software built outside of Quartus.
My hardware team wants to send a file holding all the material ( everything in both .pof files ) to the manufacturer so that they can program the devices in a prom burner, then solder the devices to the board. The board also has a JTAG connector we can use in our repair department to reprogram both devices, but for initial manufacturing the hardware team is telling me we want to follow standard practice and use a prom burner or external programming station.
To me it seems that we would need two files, and that programming the 10M04SCU169 is not normally done in an external programming station, but I am not sure just yet.
In the programming window I was able to build a .jam file. Does this format hold the entire content of both pof files?
Thanks for any help.
