AVolo2
4 years agocan arria-10-gx run on aarch64 nvidia jetson?
we got this card
can it work on jetson board?
https://www.intel.com/content/dam/www/central-libraries/us/en/documents/intel-pac-with-arria-10-gx-product-brief.pdf
It is listed in lspc...
JohnT_Altera
4 years agoHi,
You may try with the default driver to see if it is working or not. If it is not working then you might need to modify the driver where you can get the source code of the driver from https://opae.github.io/2.0.11/index.html.
- AVolo24 years ago
Thank you for your reply.
I will try https://opae.github.io/2.0.11/docs/install_guide/installation_guide.html#system-compatibility
But what exactly the way to try the default driver? What are the steps to do so ? Could you extend, please?
-BR
AV
