11 years agoCan Altera GPIO pins read analog values?
I'm a beginner in electronics so forgive me :D, Hi, can Altera GPIO pins read analog output of a light sensor? the light sensor output is analog and I want to tell the Altera whenever the signal ...
11 years agoSimple op-amp comparator should work, but you will need to change the reference by hardware if you want to set different threshold. The MAX10 ADC has a function of allowing you to set threshold. So you just change parameter in software. Much easier than hardware modification.
