xytech
Contributor
7 years agoCan A10 INIT_DONE be pulled up to 3.3V?
Hi there, We plan to connet INIT_DONE signal to MCU(3.3V) so we could know when A10 FPGA enters user mode. Although INIT_DONE is an Open-Drain output, however, A10 pin-connection guide.pdf page10 ...
ChiaLing_T_Intel
Contributor
7 years agoHi XY,
For your information, INIT_DONE is a dual purpose pin which can be used as an I/O pin when not enabled as the INIT_DONE pin. However when you use this pin in configuration mode, you have to enable the INIT_DONE pin in the Intel Quartus Prime Software and connect it to an 10kohm pull up resistor to VCCPGM. It is powered up by VCCPGM when used as dedicated INIT_DONE pin. You can connect it to VCCIO if it is used as an I/O pin.
Thank you
Chia Ling
xytech
Contributor
7 years agoThanks, understand.
