17 years agoCan a bidirectional port becomes both input and output at the same time?
I would like to create VHDL codes which are able to display data to the Input/Output port as well as receiving values of the port, if there is any changes to the port. Firstly, is it possible without...
17 years agoOoh. this mean that i can assign as inout and connect it to the external ports then control it by using an output enable bit and at the same time continuously reading the ports value is it?
