17 years agoCan a bidirectional port becomes both input and output at the same time?
I would like to create VHDL codes which are able to display data to the Input/Output port as well as receiving values of the port, if there is any changes to the port. Firstly, is it possible without...
17 years agoActually, I wanted to assigned those bidirectional pins to the DE1 development board so that I can input values from external sources and as well as output values internally from the same pins. I wanted to create a pin which acts both as input and output so that it is not specifically tied to input nor output.
