12 years agoCamera writing images to SDRAM, and needs to output to VGA monitor real time
Basically we store the images (around 15 fps from the camera) in a memory (32 MB SDRAM in my case, i cant use the SRAM since its only small like 32 to 64 k bytes and its not enough to store the 640 b...
12 years ago --- Quote Start --- 1.) How can we solve that issue / sdram contention? --- Quote End --- You need to add arbitration logic. If you are using Qsys/SOPC Builder, it will do this automatically for you; otherwise, write it yourself. --- Quote Start --- 2.) Um the vga , when it requests for the pixel values, the values needs to be there immediately. The problem is we are using SDRAM and in order to read a value from a given address, itt akes around a few clock cycles or latency I am afraid it will be complicated --- Quote End --- You need to add an appropriately sized buffer (FIFO) to both your camera writing and VGA reading components [or elsewhere in the design]. You need to efficiently write/read the SDRAM using burst transactions. An underrun condition on the VGA (or an overrun condition on the camera) is a critical problem and you should be sure to have status bits to indicate the condition has occurred.
