14 years agoCamera Design
I am working on a project that involves inputing data from 3-6 machine vision cameras (6 monochrome or 3 color) performing some basic image processing on the streams from the cameras and then saving ...
14 years agoYes, it's likely. You'll need enough I/O pins to handle all the cameras (8, 10, 12 or 16 data lines plus clock, line_valid & frame_valid for each camera). It sounds like your processing is pretty simple so you won't need a lot of resources. You can try it all out in Quartus first without building anything.
