16 years agoCalculation of Number of embedded multiplier
Operation: z<= a*b; Therer are 2 cases below and I need someone to explain on how the number below obtained. Pls explain the reason there are uses of mixed sign, unsigned and signed multiplier...
16 years agoSince the device's multipliers can only handle 18x18 multiplications, larger multiplications are implemented using several partial multiplications, like you learned in school.
Thus, a full 32x32 multiplication requires 4 partial multiplcations. And since the signal is in the MSB, the other parts are handled as unsigned. 1st a[17:0] * b [17:0] - unsigned * unsigned 2nd a[31:18] * b [17:0] - signed * unsigned 3rd a[17:0] * b [31:18] - unsigned * signed 4th a[31:18] * b [31:18] - signed * signed Thus, the mix you're seeing in the report. As for case 2, since you're only keeping the result's 32 LSBs, the 4th term isn't needed.
