Calculate skew timing with Cyclone V and ksz9031
hello,
i have troubles with the ethernet bandwith and retransmissions (ack). after some diagnostic i think it is an timing issue.
the wire length from the fpga -> knz9031 is:
| mil | mm | m | delay | delay | |
| RX_DV | 1692,83 | 42,997882 | 4,30E-02 | 227,5E-12 | 228ps |
| RX_CLK | 1649,35 | 41,89349 | 4,19E-02 | 221,7E-12 | 222ps |
| RXD0 | 1684,72 | 42,791888 | 4,28E-02 | 226,4E-12 | 226ps |
| RXD1 | 1648,24 | 41,865296 | 4,19E-02 | 221,5E-12 | 222ps |
| RXD2 | 1681 | 42,6974 | 4,27E-02 | 225,9E-12 | 226ps |
| RXD3 | 1677,12 | 42,598848 | 4,26E-02 | 225,4E-12 | 225ps |
| TX_EN | 1625,87 | 41,297098 | 4,13E-02 | 218,5E-12 | 219ps |
| GTX_CLK | 1629,75 | 41,39565 | 4,14E-02 | 219,0E-12 | 219ps |
| TXD0 | 1633,94 | 41,502076 | 4,15E-02 | 219,6E-12 | 220ps |
| TXD1 | 1657,65 | 42,10431 | 4,21E-02 | 222,8E-12 | 223ps |
| TXD2 | 1657,33 | 42,096182 | 4,21E-02 | 222,7E-12 | 223ps |
| TXD3 | 1655,12 | 42,040048 | 4,20E-02 | 222,4E-12 | 222ps |
all wires are the same length, in every wire is an 22r resistor. the design is bought and not designed by us.
i found the following knowledge base entry:
https://www.intel.com/content/www/us/en/support/programmable/articles/000079123.html
=> TX_CLK to TXD/TX_CTL output data delay is specified as -0.85 to 0.15 ns
Datasheet 9031:
For the receive path (KSZ9031RNX to MAC), the KSZ9031RNX adds 1.2 ns typical delay to the RX_CLK output pin, with respect to RX_DV and RXD[3:0] output pins.
We use kernel v4 with u-boot and devicetree, after a lot of measuring and test,
i got the best result with this skew timing:
&gmac1 { status = "okay"; phy-mode = "rgmii"; /* 0 bis 900*/ rxd0-skew-ps = <420>; rxd1-skew-ps = <420>; rxd2-skew-ps = <420>; rxd3-skew-ps = <420>; rxdv-skew-ps = <420>; txd0-skew-ps = <360>; txd1-skew-ps = <360>; txd2-skew-ps = <360>; txd3-skew-ps = <360>; txen-skew-ps = <360>; /* 0 bis 1860*/ rxc-skew-ps = <1680>; txc-skew-ps = <1740>; max-frame-size = <3800>; };
But how could i calculate the skew timing?
Which timing should be the best, with mathematics
- Nurina
We do not receive any response from you on the previous question/reply/answer provided. Please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
- qwitza
thanks a lot for the great answer and all the work!
I ve test a lot of different skew parameter. I started with the calculated skew parameter.
procedure:
- send an file pc => cyclone 5 processor
- count the ack errors with wireshark
- receive an file pc <= cyclone 5 processor
- if number of tries < 10 goto 1
- else change the skew parameter goto 1)
the file is 1gb big, and i ve get the best skew values with:
rxdX 420 txdX 360 rxc 1680 txc 1740
i think i can only verify the parameter with an oscilloscope, but at the moment i have not the necessary equipment for that.
thanks again for the support and the endurance.
- qwitza
i have additional questions.
we tested now more than 10 boards with our new device tree, and have the following result.
File embedded system => PC:
if we copy an file from our embedded system to the pc, we have no or less retransmission, < 5 retransmission per copy.
all 10 boards have the same result
File PC => embedded system:
8 boards:
if we copy an file from our embedded system to the pc, we have no or less retransmission, < 55 retransmission per copy.
2 boards:
have really a lot of > 400 ack retransmissions, and ack fast retransmissions.
Result:
the ack retransmission error is always from pc to our embedded system, which connection is bad.
Where can we start troubleshooting?
- Nurina
This thread has already transitioned to community support.
Please post a new thread for Intel support.
Nurina
- qwitza
the retransmission error results from an to low voltage supply for the ksz9031.
DVDDL was 0,1mV to low.
thanks for your support.
