qwitza
3 years agoCalculate skew timing with Cyclone V and ksz9031
hello,
i have troubles with the ethernet bandwith and retransmissions (ack). after some diagnostic i think it is an timing issue.
the wire length from the fpga -> knz9031 is:
mil
qwitza
3 years agoHello,
thanks a lot for the great answer and all the work!
I ve test a lot of different skew parameter. I started with the calculated skew parameter.
procedure:
- send an file pc => cyclone 5 processor
- count the ack errors with wireshark
- receive an file pc <= cyclone 5 processor
- if number of tries < 10 goto 1
- else change the skew parameter goto 1)
the file is 1gb big, and i ve get the best skew values with:
| rxdX | 420 |
| txdX | 360 |
| rxc | 1680 |
| txc |
1740 |
i think i can only verify the parameter with an oscilloscope, but at the moment i have not the necessary equipment for that.
thanks again for the support and the endurance.
