Calculate skew timing with Cyclone V and ksz9031
hello,
i have troubles with the ethernet bandwith and retransmissions (ack). after some diagnostic i think it is an timing issue.
the wire length from the fpga -> knz9031 is:
| mil | mm | m | delay | delay | |
| RX_DV | 1692,83 | 42,997882 | 4,30E-02 | 227,5E-12 | 228ps |
| RX_CLK | 1649,35 | 41,89349 | 4,19E-02 | 221,7E-12 | 222ps |
| RXD0 | 1684,72 | 42,791888 | 4,28E-02 | 226,4E-12 | 226ps |
| RXD1 | 1648,24 | 41,865296 | 4,19E-02 | 221,5E-12 | 222ps |
| RXD2 | 1681 | 42,6974 | 4,27E-02 | 225,9E-12 | 226ps |
| RXD3 | 1677,12 | 42,598848 | 4,26E-02 | 225,4E-12 | 225ps |
| TX_EN | 1625,87 | 41,297098 | 4,13E-02 | 218,5E-12 | 219ps |
| GTX_CLK | 1629,75 | 41,39565 | 4,14E-02 | 219,0E-12 | 219ps |
| TXD0 | 1633,94 | 41,502076 | 4,15E-02 | 219,6E-12 | 220ps |
| TXD1 | 1657,65 | 42,10431 | 4,21E-02 | 222,8E-12 | 223ps |
| TXD2 | 1657,33 | 42,096182 | 4,21E-02 | 222,7E-12 | 223ps |
| TXD3 | 1655,12 | 42,040048 | 4,20E-02 | 222,4E-12 | 222ps |
all wires are the same length, in every wire is an 22r resistor. the design is bought and not designed by us.
i found the following knowledge base entry:
https://www.intel.com/content/www/us/en/support/programmable/articles/000079123.html
=> TX_CLK to TXD/TX_CTL output data delay is specified as -0.85 to 0.15 ns
Datasheet 9031:
For the receive path (KSZ9031RNX to MAC), the KSZ9031RNX adds 1.2 ns typical delay to the RX_CLK output pin, with respect to RX_DV and RXD[3:0] output pins.
We use kernel v4 with u-boot and devicetree, after a lot of measuring and test,
i got the best result with this skew timing:
&gmac1 { status = "okay"; phy-mode = "rgmii"; /* 0 bis 900*/ rxd0-skew-ps = <420>; rxd1-skew-ps = <420>; rxd2-skew-ps = <420>; rxd3-skew-ps = <420>; rxdv-skew-ps = <420>; txd0-skew-ps = <360>; txd1-skew-ps = <360>; txd2-skew-ps = <360>; txd3-skew-ps = <360>; txen-skew-ps = <360>; /* 0 bis 1860*/ rxc-skew-ps = <1680>; txc-skew-ps = <1740>; max-frame-size = <3800>; };
But how could i calculate the skew timing?
Which timing should be the best, with mathematics
- qwitza
the retransmission error results from an to low voltage supply for the ksz9031.
DVDDL was 0,1mV to low.
thanks for your support.
- qwitza
i have additional questions.
we tested now more than 10 boards with our new device tree, and have the following result.
File embedded system => PC:
if we copy an file from our embedded system to the pc, we have no or less retransmission, < 5 retransmission per copy.
all 10 boards have the same result
File PC => embedded system:
8 boards:
if we copy an file from our embedded system to the pc, we have no or less retransmission, < 55 retransmission per copy.
2 boards:
have really a lot of > 400 ack retransmissions, and ack fast retransmissions.
Result:
the ack retransmission error is always from pc to our embedded system, which connection is bad.
Where can we start troubleshooting?
- Nurina
This thread has already transitioned to community support.
Please post a new thread for Intel support.
Nurina
- Nurina
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
- qwitza
thanks a lot for the great answer and all the work!
I ve test a lot of different skew parameter. I started with the calculated skew parameter.
procedure:
- send an file pc => cyclone 5 processor
- count the ack errors with wireshark
- receive an file pc <= cyclone 5 processor
- if number of tries < 10 goto 1
- else change the skew parameter goto 1)
the file is 1gb big, and i ve get the best skew values with:
rxdX 420 txdX 360 rxc 1680 txc 1740
i think i can only verify the parameter with an oscilloscope, but at the moment i have not the necessary equipment for that.
thanks again for the support and the endurance.
- Nurina
We do not receive any response from you on the previous question/reply/answer provided. Please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nurina
- Nurina
Posting the solution here for the community's future reference.
Regarding the PCB traces, resistors etc.
Typically we take into account the track lengths on PCB, line impedance and capacitive loading. All of which are inter-related. The track delay data you have is quite impressive and has pretty high tolerance to variations. Therefore, track delay can be ignored from analysis.
TX Timing
Examining the RGMII 2.0 spec: (see attached)
At the transmitter, TX_CTL & TXD are sent edge-aligned to TXC by the transmitter. However at the receiving end, the TXC signal is center-aligned to data. According to the spec, the skew can be achieved by PCB trace routing or by an internal delay in the transmitting or receiving node.
Assuming the following:
- With the HPS we can’t add 2.0 ns of delay to TXC
- The customer hasn’t added the skew via PCB
- All tracks on PCB are delay matched
- Paths are delay matched within the PHY package
Then the only option is to add the delay within the PHY.
Here’s what we publish wrt TX:
The PHY allows for internal delays on TX_CLK via MMD register 2.8. The goal would be to center-align the signals to TX_CLK by delaying TX_CLK.
As a default, the PHY adds a 15*0.06ns = 0.900 ns delay to TX_CLK. However to center-align, TX_CLK should be delayed 1.65 ns.
Therefore if the customer sets MMD register 2.8[9:5] to int(1.65/0.06) = 27 or 1.62ns. This will provide a Tsu of 1.47 ns and Th of 1.53 ns. This should easily meet the TsetupR & TholdR requirements of 1.0 ns.
RX Timing
Like the Tx timing, the PHY sends its data edge aligned to RXC. At the receiving end, the RXC signal is center-aligned to data. According to the spec, the skew can be achieved by PCB trace routing or by an internal delay in the transmitting or receiving node.
- With the HPS we can’t add 2.0 ns of delay to RXC
Here’s what we publish wrt RX:
As before, the PHY allows for internal delays on RX_CLK via MMD register 2.8. The goal would be to center-align the signals to RX_CLK by delaying RX_CLK.
Examining Table 4-6 from above, as a default, the PHY adds a 15*0.06ns = 0.900 ns delay to RX_CLK. However to center-align, RX_CLK should be delayed 2.00 ns. Therefore if the customer sets MMD register 2.8[4:0] to int(2.0/0.06) = 33 or 1.98ns. This will provide a Tsu of 1.98 ns and Th of 2.02 ns. This should easily meet the TsetupR & TholdR requirements of 1.0 ns.
Final Notes
The above analysis is fairly simplistic. It doesn’t take into account duty-cycle distortion, jitter, IO skew, PCB skew, or variations over PVT. Here’s a TI appnote the tries to address some of these concerns.
https://www.ti.com/lit/an/snla243/snla243.pdf
Lastly, the customer can scope these signals & validate the clock-data relationships.
- Nurina
Can you provide some updates?
Nurina
- Nurina
I am had problems trying to add comment on here so I have sent you a response through email.
Please let me know if it helps.
Nurina
- Nurina
The wire lengths in your PCB are all the same right?
Is there resistors in every wire? Where do you have this resistor?
Nurina
- qwitza
the wire length is in my first post, and yes they have all very near the same length.
the ksz9031 and the cyclone v are on the top layer, the resistors are on the bottom layer. the resistors are placed near the ksz9031.
thanks for your work, and answer
- Nurina
Thank you for sending your .qar file, I have sent this to internal team and they will give suggestions soon.
Nurina
