12 years agocalculate 64 bit unsigned
hi, i've implemented a nco megafunction with a 64 bit phase accumulator in order to obtain very high precision output frequencies. Now to be able to program externally (by microcontroller for ex...
12 years agook I'll try this way then I'll let you know...
i don't understand the constant temp.... So if my numbers is: Fo=4050Hz Fclk=250Khz N=64 how could i put them in your code? Thanks
