17 years agoC3 - Ep3c80
I am planning on configuring this C3 device using the Active Parallel method with a Numonyx CFI flash device. Is there any way of having multiple configurations within the FLASH and choosing between them? If so how? Thank you, Rob1 Reply
The Cyclone III will always load the same configuration from the flash at power up. But then, you can have it load a new configuration at another place. Have a look at application note 521 (http://www.altera.com/literature/an/an521.pdf).
