16 years agoByteBlasterMV programming with JTAG disabled
I’ve disabled JTAG so I can use the JTAG pins for I/O and used a JBC file to program an EPM7064S using ByteBlasterMV. Using a POF file doesn’t work. As far as I can tell the programming s...
16 years ago --- Quote Start --- If I understand right, your way of programming is a one way ticket. You can't neither verify nor reprogram the chip. If you want to, you need a programmer that supports a high voltage programming method, e.g. the Altera Programming Unit (APU). --- Quote End --- Hi thanks for your comment but I’ve found it does work. I’ve programmed it with a good design and it works. I then programmed it with a bad design and it stopped working as I expect. I’ve programmed it with a good design and it works again. I’ve not checked if the JTAG pins have been programmed correctly so it is possible it’s only been partial programmed. I will check this out later on when I have time and report back. Terry
