16 years agoByteBlasterII JTAG chain problem detected
Hi I´m trying to program a EP3C5E144C8N FPGA in JTAG mode using a ByteBlasterII cable. The pins are connected as indicated in the JTAG configuration of a single device using a download cable (Fig ...
16 years agoOne of the suggestions at the top was..
'The TDO connection to the dowload cable migth be shorted to GND or is an open circuit' Did you try buzzing the TDO to GND to check if ther is a short. Is it actually adjacent to a GND pin on the pin-out ? TDO should give something out. KR Paul
