17 years agoButtons communication problem NIOS II
Hello everybody, I created a design with buttons where a led lights on when pressing a button. My quartus II design works; I checked the pin assignments and the buttons signals with SignalTap. ...
17 years agoThanks for helping me. Here is my top level entity :
module niossram ( // inputs: osc_clk, reset_n, button, // outputs: flash_ssram_a, flash_ssram_d, led, ssram_adsc_n, ssram_bw_n, ssram_bwe_n, ssram_ce_n, ssram_clk, ssram_oe_n ); input osc_clk; input reset_n; input [ 3: 0] button; output [ 23: 0] flash_ssram_a; inout [ 31: 0] flash_ssram_d; output [ 3: 0] led; output ssram_adsc_n; output [ 3: 0] ssram_bw_n; output ssram_bwe_n; output ssram_ce_n; output ssram_clk; output ssram_oe_n; wire [ 3: 0] led_n; wire [ 3: 0] button_n; assign ssram_clk = osc_clk; assign led = ~led_n; niossram_sopc niossram_sopc_instance ( .in_port_to_the_button_pio (button_n), .adsc_n_to_the_ssram (ssram_adsc_n), .bw_n_to_the_ssram (ssram_bw_n), .bwe_n_to_the_ssram (ssram_bwe_n), .chipenable1_n_to_the_ssram (ssram_ce_n), .address_to_the_ssram (flash_ssram_a), .data_to_and_from_the_ssram (flash_ssram_d), .clk (osc_clk), .out_port_from_the_led_pio (led_n), .outputenable_n_to_the_ssram (ssram_oe_n), .reset_n (reset_n), ); endmodule
