16 years agoBurst Reads with NIOS II
I am trying to use the NIOS processor to read some debug data that has been dumped on a Memory Mapped device on the Avalon bus, using burst reads. However, I am stuck in writing the C code. I am not ...
16 years agoThe caches in the Nios CPU can issue burst reads. When you perform a regular read operation (i.e. through a pointer and not an IORD macro) and if you have a data cache, the cache will read a full cache line. If you enabled bursts access for the cache, it will do so with a burst read.
