9 years agoBurst operation in avalon bfm.
I am doing burst write operation using avalon bfm. For burst operaion shall i need to pass the data and address for all burst or bfm will automatically generate the data and address. In below task i am only passing base address and the randomized data. But in simulation result I am getting only one data. Please anyone give me some idea about this. task automatic mm_send_cfg_write; input [34:0] addr; input int data[int]; `MM_BFM.set_command_address(addr << 2); `MM_BFM.set_command_burst_count(8); `MM_BFM.set_command_burst_size(8); `MM_BFM.set_command_init_latency(0); `MM_BFM.set_command_request(REQ_WRITE); for(i=0;i<8;i++) begin `MM_BFM.set_command_data((data),i);\`mm_bfm.set_command_byte_enable(4'hf,i);
end
`mm_bfm.set_command_idle(0, 0);
`mm_bfm.set_command_timeout(0);
`mm_bfm.push_command();
while (`mm_bfm.get_response_queue_size() != 1)
@(posedge `mm_bfm.clk);
`mm_bfm.pop_response();
$display("%0t mm traffic generator id configuration write: addr: 0x%h data 0x%h",$time, addr, data);
$display("mm traffic generator id configuration write: addr: 0x%h data: 0x%h", addr, data);
endtask
task data_init(output [31:0] data [int]);
for(i=0; i<8; i++)
data = {$random(), $random()}; endtask initial begin data_init(); mm_send_cfg_write('d0,wdata); end Thanks venkat
