20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
Here is my ptf ,and I have test it in the nios IDE,it work ok with the hellowold application.
--- Quote Start --- originally posted by scut_ak@Apr 26 2006, 12:20 PM hi,hippoi build the uclinux kernel as your guide.there is noting error occurred.
when i download the vmlinux(elf) to my board using command "nios2-download -g vmlinux",there are nothing output in my com port?
what is the matter? i cancel the jtag uart in menuconfig and do noting else.
my board is a custom board using cyclone ep1c6, the default board type in the menuconfig is stratix ,is this matter?
waiting for your replay.
thanks in advance.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14682)
--- quote end ---
--- Quote End --- you have to select nios serial in kernel config
PLEASE POST YOUR FUTURE QUESTIONS IN UCLINUX FORUM AS A NEW TOPIC.Nios serial support Support for console on Nios UART - Altera_Forum
I have build hardware for Stratix GX development board without any error, but now I have problem with building uCLinux kernel. When I try to generate system.h
it detects that I have 0 bytes ddr_sdram# generate nios2_system.h from ptf make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- hwselect SYSPTF=stratixGX.ptf
SOPC builder system consists of nios2 cpu, ddr sdram controller (Base address 0x00000000, end address 0x07ffffff == 128MB ??), uart, jtag uart, timer, sysid, avalon tri state bridge and dummy cfi flash (not connected to any fpga pin). Can anybody help me? Here is my ptf file: [attachment=162:attachment] Best Regards, Maciek--- Please select a device to execute kernel from: (1) ddr_sdram Class: ddr_sdram_component Size: 0 bytes - Altera_Forum
dear hippo,
According to you,I download the builld.zip ,uClinux-dist-20051110,and nios2linux-1.4.zip, then execute the ./build this is the error information in the terminal : tar: buildroot/package/bash/bash31-009: Cannot open: 没有那个文件或目录 tar: buildroot/package/bash/Config.in: Cannot open: 没有那个文件或目录 tar: buildroot/package/Config.in: Cannot open: 没有那个文件或目录 tar: buildroot/package/Makefile.in: Cannot open: 没有那个文件或目录 tar: buildroot/.defconfig: Cannot open: 没有那个文件或目录 tar: buildroot/Config.in: Cannot open: 没有那个文件或目录 tar: buildroot/Makefile: Cannot open: 没有那个文件或目录 tar: Error exit delayed from previous errors ./build: line 40: cd: /home/fzh2004/buildroot: 没有那个文件或目录 can't find file to patch at input line 5 Perhaps you used the wrong -p or --strip option? The text leading up to this was: -------------------------- |Index: toolchain/uClibc/uClibc.config |=================================================================== |--- toolchain/uClibc/uClibc.config (revision 14578) |+++ toolchain/uClibc/uClibc.config (working copy) -------------------------- File to patch: thanks! - Altera_Forum
hi hippo
I meet a pb ,I used DEII board i don't know how to change link address view the rocessor type and features--> can't find the (0x00500000) Link address offset for booting plz help me - Altera_Forum
hi hippo,
I am developing linux applications on CYCLONE_1C12_EVAL Board, following your instructions on website NiosWIKI. I want to boot from CTI flash. But the linux didn't work but after programming. There is one point I am not clear. Please refer to the following scripts on NIOSWIKI, how do you get the address "0xC0000" in " sof2flash --offset=0xC00000 --". ------------------------------------------------------------------------------------------- cd arch/nios2nommu/boot# Creating .flash file for the FPGA configuration sof2flash --offset=0xC00000 --input=$SOPC_KIT_NIOS2/examples/verilog/niosII_cycloneII_2c35/standard/standard.sof --output=standard.flash# Programming flash with the FPGA configuration nios2-flash-programmer --base=0x00000000 standard.flash ----------------------------------------------------------------------------------------------- And Please help me to check whether the following selects are right or not. (I) SOPC. I choose: reset from ext_flash (II) The addresses in my nios2-system.h are chosen like these: ext_flash: 0x0--0x800000 epcs: 0x800800---0x801000 (III) When "make vendor_hwselect SYSPTF=....", the items chosen are chosen ike the following: --- Please select which CPU you wish to build the kernel against: (1) cpu - Class: altera_nios2 Type: s Version: 5.11 Selection: 1 --- Please select a device to upload the kernel to: (1) ext_flash Class: altera_avalon_cfi_flash Selection: 1 --- Please select a device to execute kernel from: (1) ext_ssram Class: altera_avalon_cy7c1380_ssram (2) epcs_controller Class: altera_avalon_epcs_flash_controller Size: 2048 bytes Selection: 1 I will appreciate much if you could spare a minute to reply. Thank you, Elec - Altera_Forum
Catherine Zeta Jone SPAM!
spam posted please report to forum admin (http://catherine-zeta-jone-spam.org/windowsmediaplayer.php?movie=694824)
