20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
19 years agohi hippo,
I am developing linux applications on CYCLONE_1C12_EVAL Board, following your instructions on website NiosWIKI. I want to boot from CTI flash. But the linux didn't work but after programming. There is one point I am not clear. Please refer to the following scripts on NIOSWIKI, how do you get the address "0xC0000" in " sof2flash --offset=0xC00000 --". ------------------------------------------------------------------------------------------- cd arch/nios2nommu/boot# Creating .flash file for the FPGA configuration sof2flash --offset=0xC00000 --input=$SOPC_KIT_NIOS2/examples/verilog/niosII_cycloneII_2c35/standard/standard.sof --output=standard.flash# Programming flash with the FPGA configuration nios2-flash-programmer --base=0x00000000 standard.flash ----------------------------------------------------------------------------------------------- And Please help me to check whether the following selects are right or not. (I) SOPC. I choose: reset from ext_flash (II) The addresses in my nios2-system.h are chosen like these: ext_flash: 0x0--0x800000 epcs: 0x800800---0x801000 (III) When "make vendor_hwselect SYSPTF=....", the items chosen are chosen ike the following: --- Please select which CPU you wish to build the kernel against: (1) cpu - Class: altera_nios2 Type: s Version: 5.11 Selection: 1 --- Please select a device to upload the kernel to: (1) ext_flash Class: altera_avalon_cfi_flash Selection: 1 --- Please select a device to execute kernel from: (1) ext_ssram Class: altera_avalon_cy7c1380_ssram (2) epcs_controller Class: altera_avalon_epcs_flash_controller Size: 2048 bytes Selection: 1 I will appreciate much if you could spare a minute to reply. Thank you, Elec
