20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
20 years agohi hippo
Do you have drive "dm9000" chip on DE2 board ? when i make kernel and occur error info: drivers/char/mem.c: In function `mmap_kmem': drivers/char/mem.c:276: warning: cast to pointer from integer of different size CC drivers/char/random.o drivers/char/random.c: In function `random_write': drivers/char/random.c:1032: warning: comparison of distinct pointer types lacks a cast CC drivers/char/tty_io.o CC drivers/char/n_tty.o CC drivers/char/tty_ioctl.o CC drivers/char/misc.o LD drivers/char/built-in.o CC drivers/hwmon/hwmon.o LD drivers/hwmon/built-in.o CC drivers/net/Space.o CC drivers/net/loopback.o CC drivers/net/dm9000x.o drivers/net/dm9000x.c:305: error: `na_dm9000_irq' undeclared here (not in a function) drivers/net/dm9000x.c: In function `dmfe_probe': drivers/net/dm9000x.c:362: error: `na_dm9000' undeclared (first use in this function) drivers/net/dm9000x.c:362: error: (Each undeclared identifier is reported only once drivers/net/dm9000x.c:362: error: for each function it appears in.) drivers/net/dm9000x.c:434:24: warning: "HDX32" is not defined drivers/net/dm9000x.c: At top level: drivers/net/dm9000x.c:291: warning: 'dmfe_debug' defined but not used drivers/net/dm9000x.c:295: warning: 'debug' defined but not used drivers/net/dm9000x.c:296: warning: 'mode' defined but not used drivers/net/dm9000x.c:785: warning: 'dmfe_reset_dm9000' defined but not used make[2]: *** [drivers/net/dm9000x.o] Error 1 make[1]: *** [drivers/net] Error 2 make: *** [drivers] Error 2 http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Before,i have make kernel on Window XP and occur same error info. Do you solve it ? Thx thx
